av8or »
https://forums.nicoclub.com/av8or-u92327.html
Fri Oct 17, 2008 4:11 am
my power window has been acting up lately..nothing wrong with the motor, but when i roll my window down, sometimes it won't roll back up... only solution i have figured out is hitting the window switch from the side a couple of times.. after doing so, window will roll back up.. one time, the window didn't go down when i opened the door... i should also add that there is a intermitent creaking sound when the window has reached full down or up before the motor stops, like the motor is still running when it should have already disengaged.. what gives? window switch costs $245..
