yes only when is at temp, in fact when is cold i have to be careful with the throttle, the rear end loves to slide around when the car is cold.
some times to get it going too after not making a complete stop, i have to floor it, and then it thinks about it for a second and shoots like a rocket, but if i won't floor it, it just as slow as a prius...
what is a closed loop fueling issue? so when the car is cold, it does not uses sensor readings? im confused.
and is the're a more common spot for vacuum leaks? or it could be anywhere? would this diagram from tt help?
http://www.twinturbo.net/nissan/300zx/f ... agram.html
and it just might be a vacuum leak, when car is in park it revs high, but when i put it in drive, it goes back to normal... ( auto, OH THE SHAME ahah )
