So you basically took the engine cover off, removed the bolts and brackets for the upper intake plenum (and I guess some hoses and any other item that would be in the way?), and moved it out of the way (resting on the throttle body) and had access to the screws that way?Litey wrote:I can tell you after doing this 3 weeks ago that I did Re-use the gaskets that were on there , since a service manager at
local dealership had told me it was fine . I did buy a Felpro gasket kit and had it at the ready .. in case I felt I needed to replace or damaged one .. but actually returned the box un-opened to auto parts store .
I did spray each gasket with Spray Tack , gasket sealer spray ...nice stuff , holds in place and seals well , sprayed each side .
I also did not remove the Throttle Body , I simply left all the hoses and connections to it intact and tilted the left side of upper plenum up in the air , (viewing from front) (passenger side ) on end resting on the throttle body and tied with rope the TB , leaving me with plenty of access to the screws , mine were all tight but , removed and Loc-Tite Blue each one ... All went well and done in 1.5 hours ...
All is well .
There is a bolt which holds the upper (or maybe lower) intake plenum to the intake manifold. The bolt attaches a bracket which holds the two together. The bolt is on the rear of the engine, the top of the bolt head literally faces the firewall. Here are the special tools you will need to finish this job (outside of your regular wrenches and torque wrench): a 10mm Gear Wrench (it's the ratcheting wrenches with the movable elbows) and a deep 10mm (or 12mm?) socket. I suggest buying a deep socket set which includes both a 10mm and 12mm socket. I would also recommend just buying a 10mm and 12mm Gear Wrench since they just make life easier. Other than that you should be fine, just make sure you follow the tightening patterns precisely and make sure you torque the bolts properly. If you only remove the upper and lower plenums then this job wont take more than a few hours. I purchased the Felpro gasket set from Advance for like $13 (it costs about $80 at the dealer!!!) and I also did the intake manifold.CanuckQx4 wrote:Sounds fairly straight forward
I hear a few paragraphs about 2 hard to reach bolt that you need to get at with a wrench in both explanations, but I cant figure out what bolt or what it hinders...
I think Im going to go ahead and do this, this weekend
