boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Mon Mar 22, 2004 2:02 pm
A bit of advice on the power valve, leave it open if you are not using the solenoid. If you are running big boost, leave it open (no vacuum) at all times. It seems to slow power response on big CFM turbos such as T3/T4. I used to have mine plugged to vacuum, but I always wondered why the car's take-off was so crappy. All the flow from the big turbo is being restricted by the closed butterfly plates which is a no-no for me. With a T25, I guess it's okay to leave it functioning if you have the solenoid and vacuum lines connected properly. The F/P regulator needs to be hooked to vacuum at all times.
Dee
