power upgrade ""check it out and tell me what you think""
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
SR20DET Turbo Upgrade Package Builder Turbocharger: Garret GT3076R .63 A/R Dual Ball Bearing T3 Top Mount, Ext WG +$1319 Turbo Manifold: TurboFab T3/T4 Manifold Assembly Nissan SR20DET S13 w/ top mount Manifold, Wastegate dump tube, and O2 Extension +$499
Select Turbo Line Kit:
TAKA Kit, S13 SR20DET Top Mount, set of 3 lines w/ washers, uses stock block oil banjo bolt +$185
Engine Fuel Management:
Apexi Power FC w/ Commander SR20DET +$980 Injectors: NISMO 740cc Side-feed Kit +$549 Adjustable Fuel Pressure Regulator: NISMO Adjustable Fuel Pressure Regulator Type B with Fitting - fits Greddy Intake Manifolds +$194 So what do you guys think of this for a possible power upgrade for my redtop how. this should put some huge number down. want around 400 hp so i think this would do it. just give me some sugestions
cheapscheisst
Car: 1996 240sx w/ Kouki front end
that setup is capable of putting 450+hp to the wheels. if you are only shooting for 400, i'd go with a bottom mount gt2871. anyways, the GT3076 won't hit full boost until 5000-5500 rpm. unless you have a built top end that can rev to 9k or so, that isn't going to be any fun at all.
vutony
u can get cs lines for $100
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
wow i didnt think it would take that long to spool up. the gt2871r bottem mount .86 is hwt i might go with then. but dont you ose lot of torqe qith that?
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
`SR20DET Turbo Upgrade Package Builder Quantity in Basket: none Code: TURBO-BUILDER Price: $0.00 Shipping Weight: 45.00 pounds Select Turbocharger: Garret GT2871R .64 A/R Dual Ball Bearing +$1149 Garret GT2871R .86 A/R Dual Ball Bearing +$1149Select Turbo Manifold: Peak Performance Stainless T2 Bottom Mount Manifold +$399Select Turbo Line Kit: Circuit Sports S13 Bottom Mount Turbo Line Kit, Set of 3 lines w/ washers, uses stock block oil banjo bolt +$119Select Engine Fuel Management: Apexi Power FC w/ Commander SR20DET +$980Select Injectors: TiTek DENSO 550cc Side-feed Kit +$495
this is the other set up i am looking at, this one is probly the more realistic on, less expensive! but i cant decided which turbo i would want the .64 or .86 because i have read that the .86 loses a lot of torqe but only gains about 20 more horse power. but ten i have heard that the .86 is the only one that will give you 400 whp. that is that power that i want. but give me some input. choosing between these two turbo which would you pick!????
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
SO AFTER READING SOME OTHER FORUMs i decided to go with the .64 gt2871r turbo. and use the stock manifold and just have it honed and polished inside to create better air flow. does any one know if taking the heat sheild off of the em will make the motor bay much hotter? also i was thinkning about pianting the EM with some high trmp paint. because it is all oxidized on the outside. would paint stick?
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
I have only painted N/A headers using 1400deg stove heat (for wood burning stoves). You could try to use it on your manifold and as long as you dont get too lean i think you should be ok. Have you ever thought about getting a Jet-Hot coating?
nwmrkt
Car: S13
what does type a/b mean for the nismo fuel regulator? You need to buy the adapter too right? What power can the gt2871r 86 a/r make? You can also make it external gated right?what topmount manifolds would fit it? After the gate is shut?
Thanks
Nismo_Freak
Car: 89 Nissan 240SX
nwmrkt wrote:what does type a/b mean for the nismo fuel regulator? You need to buy the adapter too right? What power can the gt2871r 86 a/r make? You can also make it external gated right?what topmount manifolds would fit it? After the gate is shut?
Thanks
They make two styles... one is remote mount the other is rail mount.
Add about 25whp to the 0.64 for the 0.86.
You can make it ext. gate, yes, but if you want ext. gate I would HIGHLY recommend the 3071R over the 2871R.
nwmrkt
Car: S13
Thanks so which one would be good for a greddy manifold? B? and stock? A?
How comparable is the 3071r to the gt8271r? Power, fullboost? lag? Also what flange is it? t3?
Thanks
grenade180sx
Car: 180sx
a gt30 will come in sooner then 5k ..
i have ran a gt30 on my sr and its came into full boost at 3700
i now have a gt35r and it comes on at 4200 and is smoother then the 30r.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
wait i am cnfused . here so te gt30 takes how long to spool up.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
how high will my engine be able to rev with these upgrades.1.Tomei Solid Lifters_2.Brian Crower Stage 1 264/264 SR20DET Camshafts3. Brian Crower Valve Springs_4. Brian Crower Ti Retainers_5. Fresh Valve Stem Seals6.Brian Crower SR20DET Valve set, intake & exhaust, Stainless7. Port and polished head
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
no one knows hw high my engine will be able to rev with these upgrades?
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
idahotuner wrote:no one knows hw high my engine will be able to rev with these upgrades?
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
You must use cams for solid lifters to use solid lifters!!!
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
bumbing my dead thread aye?
duffman1278
Car: 89 240sx Hatch, the wildcats!
Niice setup, but t28?? downgrade?? Well downgrade from the T3?
karmakaze
Car: 98 240sx SE
idahotuner wrote:`SR20DET Turbo Upgrade Package Builder Quantity in Basket: none Code: TURBO-BUILDER Price: $0.00 Shipping Weight: 45.00 pounds Select Turbocharger: Garret GT2871R .64 A/R Dual Ball Bearing +$1149 Garret GT2871R .86 A/R Dual Ball Bearing +$1149Select Turbo Manifold: Peak Performance Stainless T2 Bottom Mount Manifold +$399Select Turbo Line Kit: Circuit Sports S13 Bottom Mount Turbo Line Kit, Set of 3 lines w/ washers, uses stock block oil banjo bolt +$119Select Engine Fuel Management: Apexi Power FC w/ Commander SR20DET +$980Select Injectors: TiTek DENSO 550cc Side-feed Kit +$495
i ran the .86 and i loved it! the power FC is overkill. get an enthalpy tune instead.you will also need a z32 maf and a walbro fuel pump. thats also way to much to spend on injectors. get deatschwerks instead. go with the 740cc for $389
karmakaze
Car: 98 240sx SE
idahotuner wrote:how high will my engine be able to rev with these upgrades.1.Tomei Solid Lifters_2.Brian Crower Stage 1 264/264 SR20DET Camshafts3. Brian Crower Valve Springs_4. Brian Crower Ti Retainers_5. Fresh Valve Stem Seals6.Brian Crower SR20DET Valve set, intake & exhaust, Stainless7. Port and polished head
don't bother to port and polishing your head. for your power level it won't get you much bang for you buck. i also suggest that if you are going to run solid lifter, to get cams designed for it. and be prepared to reshim after 5000 miles.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
My head work is done already. and i didnt even do half that stuff lol.
BC cams 264BC springsNew valve seals i dont want the pain of solid lifter havign to reshim lol. i am havign enough prolems allready
check out my build it show s what i have actually beeen doing.it is in my siggy
