power transistors/ ignition control module
mikes94q
Car: 1994 Q45 61k
the power transistor or ignition control module. what is the likely hood of both of mine to go out at the same time? I pulled them to do a continuity test and both failed.
can they be repaired.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Very very unlikely.
And no they can't be repaired as far as I know.
mikes94q
Car: 1994 Q45 61k
when I try to test them with my multimeter I get the same results which turn out to be bad. no continuity at all
Q45tech
Testing transistor often requires more than a VOM. They make special alpha, beta, conductance testers.
Never seen any 90-95 ignitor failures unless destroyed while testing.
mikes94q
Car: 1994 Q45 61k
any suggestions on alternatives? after removing them the car still does the exact same thing when turning the ignition. My concern was with my vom the tests were exactly the same result with both modules.
Infinitiguy19
Q45tech wrote:Testing transistor often requires more than a VOM. They make special alpha, beta, conductance testers.
Pretty ironic
Wouldn't a faulty power transistor or two bring up a Check Engine Light code?
I have one for sale if you interested Mike.
mikes94q
Car: 1994 Q45 61k
I'm not sure about the engine code because I cant get the car to start will it give me a code?
What do you want for the part?
mikes94q
Car: 1994 Q45 61k
Also, when I put the ignition to on (of course the car still not starting) when I press the gas pedal down I here a small buzzing sound from the engine bay. Any ideas if that is normal or not?
Infinitiguy19
mikes94q wrote:Also, when I put the ignition to on (of course the car still not starting) when I press the gas pedal down I here a small buzzing sound from the engine bay. Any ideas if that is normal or not?
My car is far from normal but when I asked about this Heath said it has to do with a EGR solenoid.
Is $32 shipped for the power transistor fair? PM or email me so we can discuss further details...
You should also be able to check the ECU codes and see just in case, But if you confirmed that the transistors are bad then you may have nailed it.
mikes94q
Car: 1994 Q45 61k
I hope so let me test a bit more tonight then if thats the issue I am interested. Thanks.
So with the egr solenoid is that a bad sound or a normal (non harmful) sound
Infinitiguy19
Well Heath Q451990 says its normal, Maxnix says its not the normal operation of the car.... I think its okay.
