babysirt »
https://forums.nicoclub.com/babysirt-u93317.html
Sat Apr 19, 2008 1:54 pm
I have been having intermittent no starts so I tested the coil and resistor. They are fine. So I figured it was the power transistor.
Page 161 in the EF&EC section of the manual says that if it read infinity or zero with the positive lead on B and the negative lead on A, then the transistor is bad. I tested my transistor and the resistance between terminal A and B was infinity even when I swapped the polarity. So according to the manual, it is bad.
I went to the junkyard and pulled one of another 240SX and one of a Nissan Maxima. I tested them and they both tested the same way. Was i just really lucky and found two other bad transistors or is the manual wrong? And can I use a power transistor off any Nissan?
