Power Transistor connection?
skoob240
What does it connect to? Also, when extending the wires in the harness should I use shielded(sp?) wires or is normal ok? Anyone have any pics of how their harness is wired in?
boost_boy
The power transistor is wire to the coilpacks and fed from the engine's harness to the ecu. Normal is okay when extending, just remember to wrap it as you found it.
