The V8 CAS has 360 tiny slots, think of it as a clock ticking once every 2 degrees of crank rotation [1 per degree of cam rotation]........the SUB MASTER CLOCK for the whole ecu........there is a xtal time base for real time in microseconds so the two together create the rpm. Where the Revs and the minute get created into RPM
Since a complete brand new cycle starts every 90 degrees with a V8 [ 120 V6/I6....180 for I4]........timing is very important a 2,3,4 degree error in the start of injection or when a plug fires will not create a perfect balance of equal power pulses.
The valves and piston motion are pretty well controlled via the timing chain belt and repeatable from rpm to rpm [except initial power on and sudden power off when chain/belt slack creates tiny errors momentarily.
The CAS 360 pulse are backed up on the Q with a redundant circuit providing an every 90 degree pulse from a different disk.........the 4 slots are different widths as is the 0 slot in the 360 disk so the ecu KNOWS where the number one pistion is. 8 cycles then start again.
One needs to examine the pulse train from both circuits to see that the pulse are uniform height and duration at a steady rpm with an oscilloscope.
Background not necessarily like the Q:
http://www.donet.com/~jsg/efi332crank.h ... icokit.htm
Still you always [ALWAYS] start by measuring the fuel pressure at idle, upon acceleration [in gear driving on road] at at WOT at 4,000 and 6,000 rpm!
