Corvidae wrote:Is the ground wire on the factory harness pin 6 (the joint harness)? It seems that that pin is grounded, as I got no voltage there regardless of light status. I did all my tests against true ground, not the harness ground, so yeah, something like that could be the problem.
I'll test the impedance tonight and will let you know. Just want to make sure that I'm looking at the right place.
Thanks for the info!
No. Pin 6 goes to the joint harness, which is essentially a powered shield for the preamp signal, from what I gather from the factory service manual.
The ground on the stereo harness should be directly connected to the chassis, scraped bare metal chassis connection. The joint harness doesn't connect to any pins in an aftermarket stereo.
Pin 2, illumination control, should only be used if your stereo has a dimmer input. Otherwise, it should be left capped off and free. If it's not capped off, and shorts to ground, it will blow your clearance illumination fuse. How do I know? You're not the first one to buy a Z with shoddy audio installs
If you're running an amp, the only wires you need hooked up to your head unit would be pins 1, 3 and 8 on the 10 pin block. Run your HU ground to the chassis as mentioned and everything should work fine. If it does have an illumination input, either 2 or 7 goes there (I forget which, sorry).
