Power Sunroof Weatherstripping gone bad. What part?
RustyShackleford
Car: Red Piggy w/Black Meshies
My weather stripping on a 1990 S13 is leaking and it's on a power sunroof the piece is highlighted in the picture below. it's a piece that goes all the way around the window but I'm not sure if the part number is 91246. Here's the parts diagram that makes me believe that this is part 91246. Can anyone tell me if this is the right part? Also is there a writeup or any advice on how to change the stripping? Thanks a lot guys.
NISSAN240SX12
Car: 1993 NISSAN 240SX SE COUPE
1991 Toyota Supra
i would like to know about this also. my gasket needs to be replaced....
allmtoreg
Car: 93 240sx coupe
NISSAN240SX12 wrote:i would like to know about this also. my gasket needs to be replaced....
when i bought my car it has been sealed with rtv.....its still like that and i would like to change it
RustyShackleford
I just talked with 2 nissan dealers, performance nissan in duarte, ca and thenismoshop, and they advised me that the part can only be ordered with the entire sunroof glass which is 436 at thenismoshop and 500 at performance nissan. it's rather sad but they directed me to an autoglass repair shop and i need to investigate this further because they basically told me to get the insurance deductible and just buy the glass or try and find a sunroof specialist. i'm pretty much at a dead end.
DuckyD
Car: 1995 240SX
The sunroof is completely unservicable.
RustyShackleford
i saw an alternative for the sunroof where this guy custom cut a 1/4" lexan sunroof and put it on and it sounded like a pretty cool idea apparently it was just 65 bucks for the lexan and maybe i'll grab some weatherstripping from some auto parts store or home depot and epoxy it on. just some suggestions for y'all
allmtoreg
Car: 93 240sx coupe
someone need to do a writeup....im sick of my sunroof just being glued shut
obg3506
Car: 2006 Infiniti G35
1995 240sx SE
So if you can order just that gasket, does the fiberglass trim type thing comes with it?
Reason im asking is because i got my s14 at a body shop than can get the gasket seperately but my trim oiece is broken.
if they can perform the install i will let you all know who it is and the cost!
