Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Fri Dec 16, 2005 8:58 pm
It isn't too bad to replace the rack, you will need to unbolt the bushings turn out the out tie rod ends. Remove the inners, and it should come out easy once the lines have been removed (use a flare wrench or you will be very sorry).
