slo_coupe »
https://forums.nicoclub.com/slo-coupe-u50527.html
Sun Feb 03, 2008 6:43 pm
a p/s whine can occur if 1) there a leak in the system 2) air some how got in the system, usually by a leak or not bleeding it properly. 3) the pump is takin a **** on you 4) system is overfilled
so check your fluid. make sure its at the proper lever. make sure your fluid doesnt look cloudy, if so it has air in it. if all thats checks out good, replace the pump
