SUB ZERO CAR FANATIC »
https://forums.nicoclub.com/sub-zero-car-fanatic-u53284.html
Mon Feb 11, 2008 12:23 pm
Anyone ever had their belt jump off the water pump pulley when putting on a new belt!! I replaced all my belts no problems at all,but the belt keeps coming off the back side of the water pump pulley,like its a little too far foward.When laying under car looking up at the pulleys and belts it looks like the water pump pulley is a little farther foward than the other ones it goes around!!(power steering pump pulley, back grooves of crank pulley, and tensioner. the only thing thats not tightened is the crank pulley, and that doesnt matter because if anything would change from it being tightened it would be worse because it would push belt back even further,which is my problem now!! Pulley looks to be 1/8 to 1/4 inch to far foward. i might have to pull dust shield off of lower section of flex plate and stick a pipe or something in to wedge it.
