I am off from school right now and wanted to track down an intermittent problem with the POWER steering... When in a parking lot the power steering gives out and the steering wheel gets stiff
Thanks!
I think I will look into number 3. Possible pump replacement. Thanks for the info, I will get a kit off Z1 and rebuild a spare pump that has been kicking around. Summer Z chores.NolimitZ32 wrote: ↑Thu Jul 06, 2017 4:01 pm1. Belt Tension
2. Fluid Level/Cleanliness
3. Bad Seals - seals inside the pump age and break down allowing fluid to pass by the impeller, at higher RPM there is enough flow to push the impeller along but at low revs the flow drops below the operating threshold and the resistance on your tires rises so your pump essentially becomes useless. I would be willing to bet that this is actually the issue and you need a new pump.
