Power Steering
darksurfer81
Car: 1990 S13 RB26DETT
So hopefully once the wiring harness is done I can concentrate on other areas... my question is if any of you begginning drifters out there are running power steering on your RB? Mine is sans power steering at the moment so Im wondering if I should start sourcing parts for a power steering set up. Thanks in advance!
Sil240
Car: Nissan S13 "The One Cam Wonder"
I like my power steering.Driving the car without it was a little bit of a PITA.But once you are moving its not an issue.Def a nice upper body workout to parallel park without PS.
If you want to put it on.You need to remove the vanes out of the back of the RB pump. Block off the rear connection.I've heard some people using the KA pump but I don't know anything about that.
You will also need DOHC PS lines, if you have a S13 SOHC. Or get the DJ button PS high pressure line.
lucky7
Car: 97 RB25 S14
ive been driving mine without for a couple weeks now. you get used to it, but i would not drive mine on a track without it. maybe im too wimpy, but that crap isnt easy.
