The rack and pump are both 16mm banjo. I used some 16mm banjo to -6AN fittings, and then used high pressure power steering hose with -6AN fittings on each end. One end was a 45* the other was straight. Gave me good flexibility when installing.LEMHEAD16 wrote:you don't happen to remember what size they were do you?
You are correct.LEMHEAD16 wrote:Thanks all, great info.
I assume the PS cooler goes on the return side?
