power steering
solid
Alright sorry people might get mad with me asking this, im sure its been stated before but i realy have tried looking. Im getting a s13 swap into my s14 and someone said something about not being able to have powersteering or a/c. Is it true, and if so how would i make it work.
BuudWeizErr
P/S is fine.
Your A/C will need lines cut and welded IF YOU ARE USING SR COMPRESSOR, and there is additional wiring in the S14's.
SpeedRacer1
Car: 1990 240SX, G35
PS will work, no problem (unless you get a hicas pump). AC could work but it would take alot of time to figure how to setup the system.
solid
IC, so i most likely all the people that have a sr swap dont have a/c? Man imma die i live in cali. DAMN hot
SpeedRacer1
So do most of the people with SR's. Im sure you can learn to live without it.
Global warming, we're all in the same boat.
S13240
Yep no AC here...only if someone here was selling their sr ac lines from their front clips. I need ac lines badly...I live in the desert area and it is scorching HOT! Maybe some of you out of state guys wanna help out?
solid
Oh, well im getting a front clip, does that mean i can have ac?
spec-v5150
solid wrote:Oh, well im getting a front clip, does that mean i can have ac?
yeah same here.
IF I get a clip, do I need the power steering lines from the DOHC ka or can I use the ones from the clip. Same with A/C. We figured it would be too much trouble, so I was going to ditch a/c, but if Ic an keep it easily, I will
BuudWeizErr
You have to cut and weld if you wanna use the JDM compressor. If you have an SOHC, you have no choice, if you have a DOHC, you can use the KA compressor.
mike_do
ur car has windows doesn't it??? roll them down
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
A/C shouldn't have to require the JDM compressor unless you have SOHC(R-12) like was stated earlier. Almost all a/c systems work the same basic way. You just have to figure out your factory a/c system wiring, figure out what is being altered with it when you do the swap, and rewire as necessary. Correct me if I'm wrong, but I think that all that must be done is retain all wires that go to any a/c components. The rest is figuring out which a/c wires must go to the ecu and "a/c on" button.
I have a 95' and plan on putting my s13 blacktop motor into it while keeping a/c.
lagvoid
Would the s13 sr ps bracket line up correctly with the s14 chassis? anyone have any pictures of the ps assembly?
