I made my own custom line with AN fittings. Nice and clean. I'll have to look up the thread pitch of the adapters I bought. But you can make this line at home and it holds 2000+ psi of pressure. All the stuff is made by Earl's.midnightsliding wrote:not jacking your thread but dose anyone know the thread and pitch of the bango bolt that gose on the hi pressure side of the P/S system? or better yet anyone know what AN fiting fits in their?
Why did you have to do this? I've helped my friend install an RB25 pump onto an S14 using the S14 lines and no modifications needed.Darius wrote:KA banjo does not do the trick. I had to manually bore out my PS line on my S14 to get it to fit the larger diameter RB25 PS banjo bolt.
WTF???WideBodyCharlie wrote:so where's the pump located on the engine?
No, you can use the KA (dohc) pump with rb25 bracket.Kamin wrote:yessir you need a rb25 pump.
No, you don't need a custom mount. use an rb20 or rb25 ps bracket. not sure if they are exactly the same, but i know they are interchangeablethe_momo wrote:seems to me that a pump that is spun the same way as the rb motor does would work. like the stock 240 pump. i know custom mounts would be necessary, but thats what im looking at. i have all of my lines, but no pump or resivoir. anyone know? custom mount would be nothing for me. oh i have rb20.
SOB I already threw away my S14 PS pump I'll have to look harder I hate that RB20 PS pump.gawdzilla wrote:Guys, lets get the misinformation out of this thread...
well...?OKRB20DET wrote:will the rb25 pump, bolt up to the rb20?
sucks to not have FAST doesnt it?lucky7 wrote:Mr. integra7, we still NEED all the info you can give us on your fittings. i called the shop that has my car today, they tried ALL the AN high pressure fittings they stock, nothing fits. Ka banjo doesnt fit, nor does an Sr banjo. help us please!
here it islucky7 wrote:Mr. integra7, we still NEED all the info you can give us on your fittings. i called the shop that has my car today, they tried ALL the AN high pressure fittings they stock, nothing fits. Ka banjo doesnt fit, nor does an Sr banjo. help us please!
The stock s13 ps lines will work just like the stock s14 lines will work.Disturbe240 wrote:will this work with an s13.
or can i even use the stock ps line on the s13
thx
