911/Q45 »
https://forums.nicoclub.com/911-q45-u148.html
Thu Sep 30, 2004 12:05 pm
If you have torn boots, but no leak, you can replace them by unscrewing the tie rod ends, not removing them. The only trick is making sure you put the ends back with the exact # of threads showing that were there before you started. If the rack leaks, it needs to be removed and rebuilt or replaced.
