NH_RPS13Drifter »
https://forums.nicoclub.com/nh-rps13drifter-u24698.html
Mon Jan 17, 2005 3:15 pm
I'v got a 90' 240SX, which i'v put some work into, and am able to do most anything with out the help of a garage. Recently my belts starting squeeling and making noise, so i put some new ones in, and for a while things ran fine. Then my power steering started making a screeching noise, but only when i had my wheel all the way turned to lock on either side, and only when the car was cold. After doing some research I found out that I was supposed to use ATF instead of power steering fluid, so i bled out the old fluid and put in the ATF. I was hopeful that this was the source of my problems, but the noise is still there. I cant think of anything but a bad pump. Could this be a result of using the wrong fluid?
