Power steering: running SOHC lines w/ DOHC reservoir on KA24de
240lookis
Car: 1990 240sx hatch
So i am in the midst of my dohc swap from sohc. I just picked up a dohc reservoir. I will most likely pick up dohc p/s lines soon anyways, but i cant find any at the moment for a good price.
What are the cons, other than the rerouting, to using single cam power steering lines with a dual cam reservoir with a ka24DE engine?
I searched and couldnt find an answer.
Thanks
jeff420
Car: too many to fathom
the fact that sohc ps pump is on the opposite side as the dohc. seems to me that there would be ps lines running across the bay.
Gabes13
Car: rb20det s13
lolIf you're talking about the hard linesYeahYou'll have to fab somethingor get DE Lines.
http://www.courtesyparts.com/2....html
Gabes13
Car: rb20det s13
nissanman04
Car: '90 240SX, '95 Subaru Legacy
I just used some metric to AN adapters and earl's power steering hose with AN fittings, it's pretty simple. Two adapters on the rack (one w/ hose barb), one on the pump. High pressure line from rack to pump, rubber hose from reservoir to hose barb on rack.
240lookis
^^ how much did that end up costing?
nissanman04
240lookis wrote:^^ how much did that end up costing?
$50-$75 depending on where you get the fittings (AN hose ends tend to be relatively expensive).
240lookis
hmmm well i may just get some DOHC lines for the ease of everything.
