Postby
Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.htmlSun Feb 21, 2010 3:27 pm
I know 1991-1994 Q45t's have a little switch attached to the power steering cap that when the reservoir is low the HICAS light is triggered. Well I also know that the power steering system is a sealed system and fluid leaks and ruptures are rare if maintenance is regular on the system.
I myself am undecided on this because I check the power steering fluid more than once a week. But I just came up with the idea and wouldn't mind some input.
But is it worth adding the HICAS power steering cap to and non Q45t?
Postby
Q45tech »
https://forums.nicoclub.com/q45tech-u112.htmlTue Feb 23, 2010 2:43 pm
55 gallon drum in trunk with drip valve to replenish.
I just habitually check everything once per week, when I top off windshield washer, look under plenum and check oil/coolant bottle...............in t6he past the driveway was a good indicator.
