hey guys, i have a 95 nissan 240sx (auto) and my Power steering rack on the driver side is leaking pretty bad where the boot is located, the seal are in pretty bad shape. My question to you guys is, would it be better to replace the seals? or go with a new rack? i would go for the cheaper solution (seal kit), but im afraid that the shaft might be damaged and the seal kit wouldnt fix the problem and i would need a new shaft to go with it.
If anyone else has had this problem and you have a easy solution, let me know please!! thanks!!!
