Power Steering Rack
ONE80ESSEX
Car: 92 240sx w/ a 98 KA
I have the power steering pump and all the lines, but there is no fluid in the pump b/c i dont like p/s, i want to take the pump out and shorten the belt but i have one quick question. Ive heard rumors that if i take out the pump my steering rack will eventually freeze up, and slowly by slowly it will get harder to turn. Is this true? If so what can i do to get rid of the pump and still have my steering?
LasVegas240sx
Car: 1991 Nissan 240sx SE
Take off your pressure lines and sell them to me
I actually wondered the same, I see there's the belt there so I was just going to fix it. The pump itself is over $400 from Auto Zone so that was out of the question.
But if you decide you want to take it off, let me know. I'll buy all the hoses from you.
ONE80ESSEX
ill take the whole assembly off and sell em to you as soon as i find out if i can without my rack freezing up
mallbor240SR
Car: 240sx 1990
im driving with out PS, i cut the lines and took the pump out, its been like that for more than a year with no problems except when parking but thas ok
LasVegas240sx
Can't be too bad.... try driving with 33" tires with no P/S Did it for a week HAHA I was like screw this, I'm buying a new pump lol
ONE80ESSEX
mallbor240SR wrote:im driving with out PS, i cut the lines and took the pump out, its been like that for more than a year with no problems except when parking but thas ok
o tru, ill probably do that then
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
Just loop the two lines that come out of your rack so dirt wont get in there and you should be set. Turn the wheel so some fluid will come out of the rack before you loop them or it might blow the hose off. Leaving some fluid and protecting the insides so nothing gritty enters should protect it from the eliments and save your rack. I have a spare ps pump if somone needs it
LasVegas240sx
You have the spare hoses by chance? One of mine is punctured and I want to replace them all at once. If you have any, let me know by PM or email me at [email protected]
Red coupe
Car: 92 Nissan 240sx Coupe
the rack does need lubrication , so leave fluid in it but I would think it would be fine...
ONE80ESSEX
alright cool, ill do it, does anyone know what size belt to use on a 98 KA after removing the pump or do i just have to cut it and tell a shop to make me one that size?
TheOne
Car: 93 240sx FB
ONE80ESSEX wrote:alright cool, ill do it, does anyone know what size belt to use on a 98 KA after removing the pump or do i just have to cut it and tell a shop to make me one that size?
am wondering that too, what size belt would go for just the water pump & crankshaft pulley?.
(and that wouldn't sort of overspin the waterpump?, or i take it the waterpump can handle it.(i mean cause shorter belt = more spinnin?))
AeonTorpor
Car: 1991 Nissan 240SX SE
the length of the belt has nothing to do with faster or slower turning. The speed is based on the ratio of the driving pulley to the accessory pulley.
ONE80ESSEX
so then im fine eh? just need to get a belt made?
AeonTorpor
That seems to be the concensus. Just cap/loop/whatever the lines, leave fluid in the rack, and get a new belt. I haven't had any experience w/ draining or capping the lines, but i will soon. I'm planning to either get rid of my p/s and do the same capping and such, OR drain all the fluid and refill it all. And by soon I mean, when I get a job. ...
zukitek
Car: 95 240SX-SE
loop the rack hoses together so that the fluid can be retained...in order to get the belt lenth cut the belt wrap it around all the pulleys you are using then cut out the excess so that the ends meet as tight as you can pull it ,then measure the overall lenth of this .That will get you in the neighborhood .Most belts are incremented in 1/4 to 1/2 inch .There is no shop I know that "make" belts.
Ricky
Red coupe
Ive also heard of string being used to measure, though string may sink deeper into the V of the pully, and read slightly smaller then you would need.
