Power Steering question
limecorrado
Do i need to buy a ka24de power steering pump and lines for my ca18det or can i have some made and use the stock ca unit.
P.s.I tried search.
kim
Car: 90 240sx, 97 M3
I'm doing the swap right now, I read somewhere you could use the KA-E with really minor modification. I'm doing the p/w steering lines now, looks like it is possible. I'll do a write-up when I'm finished.
rico05
Car: 1992 RMS13 w/ CA18DET
I know that for my 91 KADE we just bolted the stock lines to the pump. Dunno if that helps.
RMiller
Car: BBQing
The lines from a 91-94 fit without modification. 89-90 lines do not work. You will need the lines from a 91-94. According to Heavy Throttle you only need the soft line that runs to pump, but other sources say you need them all. I have a '90 and I also have all the lines from my last '92 and I'll post pictures in a few days of what really works and what doesn't.
Twiztid_S13
Car: Cars, Anime, Women ;)
i used my ka24e lines.. just bent them carefully and they work fine.. but i also dont have ac or fan/shroud on my car.. so dunno if that helped.. dont think it matters much just gotta bend them carefully so they dont kink.
Rookie_ca18
Car: women, sleep, cars
I just bolted my ka power steering pump to my ca and put the ca pulley on it. (ka24de)
ca18detizzle
you can bend them. just be careful. if not go to a professional. if not go get the 91-94
s13conv
Car: '86 GT-S Coupe
Rookie_ca18 wrote:I just bolted my ka power steering pump to my ca and put the ca pulley on it. (ka24de)
Was that pretty easy?
I have a parts car that I can pull the lines from, but if I don't have to.....
Rookie_ca18
Yeah it was pretty easy. All I did is just removed the power steering pump from the ka and put it to side of the engine bay. Then I just removed the ka and since I didnt disconnect anything from the power steering (i.e. lines), all I had to do was remove the ca pump and use its bracket, bolt, and pulley. Good luck .
