09quickly »
https://forums.nicoclub.com/09quickly-u33561.html
Tue Aug 15, 2006 10:48 am
I have a 1992 240 convertible that has been on jackstands in my garage for about 8 months. One of the many things I pulled off, cleaned up, and generally tinkered with was the power steering assembly (I replaced the dust boots on each end, re-greased the joints). I recently got the car running again, and after addressing some leaks that I have spotted, will put it on the ground shortly. My question or issue: When I started the car, all wheels off the ground, the steering wheel went nuts. Back and forth very quickly, to the point where the whole car was vibrating up on the jack stands. I turned it off, and after a few minutes, started it again. The car ran smooth, until I attempted to turn the wheel on my own with the power steering reservoir cap off , hoping to get any air in the system out. The wheel started moving left to right again, violently, all on its own. Any theories? Does the front end need to have weight on it when the engine is running to avoid this? All new fluid, and belt is secure.
