Power steering pump...
Chimera
Car: '97 240sUx, slow as hell.
after fixing the brake problem, i also had a loud noise when i would turn the steering wheel, my bro says its the pump and needs to be replaced asap.i found a good site where i can get one:partsamerica.comquestion is which one do i get?the cardone brand w/o resevoiror the beck/arnley powersteering pumphere is the link to the 2 choices: http://www.partsamerica.com/Se...+Pumpmy bro says i need a brand new one and that used ones arent recommendedim going here cuz that ***** wont help me find or install one
navysnail
if your resovouar is still good, then you should be fine without a new one. i would just get the cardone one i guess if your tight on cash, but of course the best one would be oem.
make sure it is the pump too, dont want to spend money you dont have to
Chimera
yea my reserve isnt even touched i guess its the pump itself, so i should get the cheaper one?
navysnail
yeah, go ahead and get the cheaper power steering pump, its not to hard to replace, just make sure you refill the resivouir
NISTECH
you sure its not just a loose belt??
Chimera
the sounds starting to get worse, im pretty sure its the pump, its like loud when i turn the steering wheel, but if it is the belt where should i look?i think im gonna buy a pump soon
NISTECH
just grab ahold the belt ,while its not running, if it has excessive deflection its loose, should have no more then 1/2 an inch.
Chimera
hey my bro used a stethescope (sp?) to hear the pump mechenism...and said "yup its the pump", thank goodness i bought one instead of ordering it now.i realized its 300 bucks, but they buy back the pump from you which is about 90 bucks:)thanks for everyone that helped
