keef66 »
https://forums.nicoclub.com/keef66-u55170.html
Fri Jan 04, 2008 4:21 pm
My steering on a 2000 Q45 is a bit bumpy when I turn to left or right. I get a slight groan also, but mainly at low speeds. When I went to check the fluid, it looked like my reservoir was overfilled, but I haven't added any fluid in my memory. I then noticed that the fluid seems to be backing up into the reservoir and it has spilled out the top. Immediately after shutting off the engine, I opened the cap, and the fluid came frothing out the top--it looked like a raspberry smoothie. Does this mean I need to replace the pump?
