Power Steering Pump
chuter
I have a 1994 J30 and I do not know which P/S pump I should buy. Would it be 2 wheel steering or 4 wheel? I believe it is the 2 wheel. Also where can I order one for a good price.Is this all I will need to replace?The car is making alot of noise when I turn the wheel.Thanks,
PalmerWMD
Car: 2004 350Z
If your car is a J30t its a HICAS car and needs the 4 wheel otherwise, its the 2 wheel part.
On your trunklid it will say either J30 or J30 t..
best place for parts is infinitipartsusa.com, ask for joe and identify yourself as a NICO member.
Fred...:)
PS: Welcome to our club.:jazz:
jtesensky
Vendor
Car: 2005 Infiniti QX56
2002 Infiniti QX4
You may want to check the fluid level and look for any leaks from any of the hoses. P/S leaks aren't always easy to detect, a lot of times the fluid will leak onto a splash shield or belly pan and keep it from hitting the ground. You can call me in the morning for a price: 1.888.216.5328, I'll be glad to help! Hopefully you will just need a hose and not the complete pump . -Joe:)
chuter
Thanks for the input. My wife told me today that the car was making a noise so she stopped at a gas station and they put some P/S fluid in it. What kind? Unknown. I plan to drain the system and refill prior to P/S Pump or hoses.ATF Dexron - lll is fine right?
Thanks,
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
chuter wrote:ATF Dexron - lll is fine right?
Mobil 1 ATF is preferred by many on this board.
aaacomp
Car: Family, church, Computers, Cars
If the J is like the Q. the difference in the powersteering pump is the pully on the front and the high pressure hose mount on the rear.You can use a std pump on a Touring by replacing the pulley from the old p/s pump from the tourning to the new std pump. Last problem is the hose on the rear use the Tourning instead of the Std. hose....
Q451990
chuter wrote:My wife told me today that the car was making a noise so she stopped at a gas station and they put some P/S fluid in it. What kind? Unknown.
I sure hope they didn't use P/S fluid, rather than ATF. These fluids are entirely different, and can cause big problems if they're used in the wrong place. I'd think a service station should be aware that a lot of cars use ATF in the p/s system, so if they used the wrong stuff, they should take care of a flush for you and cover the related damage (if any). I'd check ASAP to make sure the fluid doesn't look clear (like p/s fluid) instead of RED (like ATF).
Heath
P.S. Just noticed your post was a week or so ago. It would probably be difficult to get any help from the service station at this point...
juiceman
I thought all ps fluid was transmission fluid just marketed differently? This is what I rememeber from all the other posts I have seen.
chuter
Thanks all. I drained it and installed Dexron. Seems fine now.
