Power Steering Pump Sensor
franknitty69
Car: 1995 Infiniti Q45a
Hello all,
This is hard to describe so i'll do my best.
The power steering pump has lines that go from the drivers side to the passenger side.
They connect to this rectangle shaped 'device' that has more lines coming out of it. This device has a sensor on top of it that broke. I have no idea what it is and infiniti is having a hard time determining what it is because the diagrams don't highlight this 'device'.
Does anybody know what this is? Here's an image of the broken part. The green end is what screws into the 'device', the other end plugs into a wire harness.
Here is my poor attempt at a diagram. The red circle is the sensor.
Jehangir
Car: 1992 Infiniti Q45A
I think you may have an active Q. If so I believe you are looking at the connecter for your main actuator for your active suspension. Check to see if your actsus throws a code 23. I hope this helps
franknitty69
Here's a picture of the 'device' which has the broken sensor. Please tell me what the 'device' or what the sensor is for?
thanks
franknitty69
Jehangir thanks. i hope that is not it. with the new pictures do you still think it is an active suspension part?
anyone.
help.
please.
Jehangir
Wes may recognise this. Its hard for me to tell for sure. An easier way to find out what may be wrong is to tell us what is happening in your car. Any weird lights on in the dash etc.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
That is DEFINITELY part of the active suspension... Jehangir was right on.. it is the pump accumulator for the active...
Heres a picture from the FSM...
elwesso
2007 BMW M Coupe
Not to sound conceited, but I think i pretty much kicked as$ here...... I think id make a good parts guy.....
49761-64U10- SWITCH ASSY, PRESSURE
Image below....
franknitty69
thanks wes. the infiniti parts desk was able to figure it out. the bad news is it's on back order and there is not eta date.
it was even escalated to 'customer vehicle down' and still no eta (it's been 4 weeks now).
what should i do in this scenario. the active suspension is completely disabled (meaning that it is unresponsive as if it is turned off and of course the act sus light is on).
i need this part, but i can't get it from the dealership. should i try to get the pump accumulator from a junk yard and hope that the sensor is intact?
thanks.
96Qowner
Car: 1996 Q45
Have you called Joe?:
http://www.infinitipartsusa.com/
1-888-216-5328
franknitty69
i called joe's, but i'm waiting on the status. it could be (actually should be) the same status as when i ordered from infiniit of dublin.
franknitty69
good news. the part is on its way. i'm taking it to infiniti of columbus to have it installed.
big ups to infiniti of scottsdale for coming thru in the clutch.
thanks again people.
