p00t »
https://forums.nicoclub.com/p00t-u5026.html
Sat Oct 04, 2003 8:55 am
Althought you took care of your problem i just thought i would add that, even when you loosen the tension bolt the alt and PS will stay in their position, ie. acts like its "sticking" (very hard to move back and forth). After you loosen the bolt enough just take a rubber mallet and a large screw driver and knock the accesory gently to loosen the belt (move it towards the center of the engine). Note you can only move it as far as youve turned the tensioner bolt, so make sure you arent fighting it.
You may not have noticed but when u try to loosen the tension on the belt the tensioner bolt comes out. If it worked the way it is supposed to the accessory should be moving as you turn the adjusting bolt, not the bolt itself.
Sorry if i lost you.
Example:
