I'm in the process of changing the secondary timing chain tensioners on my altima VQ35. At this point i'm stuck removing the power steering pump from its location.
I removed all the bolts supporting the pump (14mm long pivoting bolt on top, bracket tensioner and bolts) but the pump does not seems to go anywhere.
Does anyone have experience taking this pump out? At least what i need to be able to remove it from the bracket and set it aside.
