Power steering pump preassure
MulleMeck
Car: Nissan 300zx z32 Fairlady - 1991
Nissan 300zx z32 Fairlady - 1990
BMW e30 3-series - 1989
Volvo 940 - 1994
Chevrolet Starcraft G20 - 1992
Hello!
I was wondering if anyone know what the VG30DETT 1991 power steering pumps working pressure is? I'm looking for an electric alternative instead.
Thanks in advance!
MulleMeck
Volvo 940 - 1994
Anyone? :)
amc49
Car: '11 Nissan Versa
'17 Nissan Altima
A lot higher than you likely think, it varies wildly but can get to 1000 psi at max load.
macgiver
Bosch - " Electrohydraulic power steering pump" , check'm out , as a start ?? $$$$$$$ -?
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
MulleMeck wrote:
Mon Aug 26, 2019 6:05 am
Hello!
Thanks in advance!
As per the FSM ST-97 max pressure for the primary pump is 1194 psi and the secondary pump for the hi cas max 924-995 psi
Roman1
Car: 1989 Z32 2+0 Turbo
Good Morning MulleMeck,
I just tore down my 89 Z32 TT 2+0 for a series of reliability and simplicity mods.
Going to convert the power steering pump to a hydroelectric unit and the A/C compressor to an electric unit. This will allow the belt driven p/s pump and compressor to be removed making repair access a bit easier at the side of the motor.
anyhow have researched and most likely will go with a P/S pump from a 2000-2005 toyota MR2 spyder since the P/S control module is on board and will allow the speed cut for the P/S pressure so steering tightens up at higher speeds.
NolimitZ32
^ Good Info Right there!
MulleMeck
Volvo 940 - 1994
Sorry for late reply, didn't recive any notification on my mail :O
Thank you for the inputs!
Roman1 wrote:
Mon Sep 23, 2019 5:05 am
I looked that one up, sounds like a good idea. Can you tell me more about how you connect the P/S control module to the car?
