power steering pump ID
titotonto
How can I tell if the pwr steering pump that came with my clip is a hicas pump or not. I just swapped an s13 black top into a 89 240 and changed out the power steering lines to newer ones, anyway I still have no power steering so I wanted to check to see if the pump is a hicas pump.
Thanx
Dori Dori
Car: Cars of course
The hicas pump would have an extra p/s line connection b/c on a hicas car, there is an additional line that runs to the hydraulic steering pump in the rear. If you had a hicas p/s pump without that line plugged in, you should have a mess of leaking p/s fluid.
