Angell6 »
https://forums.nicoclub.com/angell6-u127756.html
Wed Feb 25, 2009 2:00 pm
I'm new here, but not to cars. I recently received and 91 Stanza with a ka24e, fwd. I've had the car since August, so I'm still fixing all the little problems the original owners didn't.
One problem (aside from wrong spark plugs, wires...) was that the pwr steering belt was too thin. It was the same belt as the water pump. What a moron, right? I replaced it with the correct one about 2 1/2 months ago. For the past month the car has had a slight squeak from the belt. Friday the car started screaming, a noise that I've never heard from a belt before. About an hour ago I turned the wheel to the right and removed the passenger side guard. To my amazement, it looked as if the power steering pump pully was grinding into the engine block. The squeaking was deff. coming from the pump. Also, the steering has been a bit shaky, the noise dies down when turning, and a really odd vibration can be felt throughout the car.
From the symptoms, I would've guessed the pump was going bad, which led me to look at it. I'm more concerned with the fact the pully is rubbing; I can't even put a fingernail between the two. If someone could please post a pic of this area, I would greatly appreciate it. I will try to post one tomorrow. It's dark here or else I would've already. Sorry so long, I just realized how much I typed. Oh yeah, I guess my question is, Is it supposed to be like that?
