worldspeaker »
https://forums.nicoclub.com/worldspeaker-u74587.html
Sat Jan 19, 2008 12:20 pm
Hi Everyone,
I have a 98 I 30 with 192,000 and up to this point really have not had to do anything with it. Now things are starting to go. I need to replace the power steering pump and wanted to ask if there is something in the vacinity of the pump that would leak oil? I cannot tell where it is coming from but I wanted to know if anyone knew of any oil leaking issues with the I 30. It runs great but is needing tlc. Any suggestions would be appreciated.
Dave
PS just in case the oil leak is just the back valve cover gasket, are there any suggestions on replacing this. Is it easy or do you have to take the entire intake manifold off?
ThanksDave
Modified by worldspeaker at 7:51 PM 1/21/2008
