power steering pump & A/C com KA to SR
vi3tkool
Car: 240sx fastback
Do KA psp & A/C com fit into redtp SR ???
S13240
91+ ka ps and ac will fit with only a few bolts, not all. I forget if you use the ka or the sr brackets though. The sr pulleys will have to be swapped over to ka .
vi3tkool
Car: 240sx fastback
thanx
Vr6WantSr20det
If u have a DOHC the power steeling lines match up, and the A/C compressor will bolt up (only the front 2 bolts). I think it sits on an offset of about 5-7mm?? using the DOHC ka compressor on the SR motor. so the belt might be at a little angle. It's like this in my friends 93 coupe with s13 sr20det. I wish i woulda known this before i got my SOHC. I am just gonna get the ends of the SR compressor lines mated to my SOHC lines for a/c.
[edit]-i've seen a post on fresh alloy of people removing the A/C bracket off the motor and having a machine shop fill/redrill the holes for the Compressor to be bolted up properly (pulleys aligned).
vi3tkool
Car: 240sx fastback
Do we have to use the SR brackets?
