power steering pulley removal. help please
akira2_03
Car: 92 240sx and 92 pathfinder
trying to figure out how to remove the pulley off the pump. what tools needed? any remove theirs and how do you do it?? need info as car is torn apart waiting for pulley to put steering all back in. please someone.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
i used an impact gun and it came right off. if you dont have one try stopping by the local mechanics and see if he wont do it right quick.
Klits562
Car: white s13 coupe
not even needed why are you removing the pully anyway?
owell all you need is i think a 16 or 19 mm socket idr and a good breaker bar. Put somethen solid in the pully to keep it from turning
akira2_03
there is no nut to unscrew though otherwise i would haveand i need to take off my pulley cause my pump i just got is from an sr20 and from what i read i need to swap the mounting bracket and the pulley to the ka24de ones
Modified by akira2_03 at 2:32 AM 9/23/2009
Klits562
ohh its a sr20 ps pump for your KA right? well you'd probably have better luck and answers in the sr20 motor forum. They will know more about the ps pumps for sr20s
akira2_03
nevermind figured things out
Modified by akira2_03 at 2:31 AM 9/23/2009
KYZAAC
Car: 92 240sx SR
care to share how you figured it out for guys like me who are in the same situation :yesnod
dmck
it is probably pressed on you need a power steering pully puller or any kind of puller realler advance should have this tool on there loaner prog. to install you just put a big socket on it and beat the pulley on whatever pump
KYZAAC
Car: 92 240sx SR
yea i have every pulley puller going and that thing won't budge, it's been sitting for a while so im guessing its seized, im just playin around with the one from the ka before i attempt to change the sr pulley
