Power steering pulley bolt
suicide commando
Car: 1993 infiniti j30
I bought a new power steering pump but it does not include the pulley. I just took my old power steering pump out and now need to remove the pulley from it. The pulley for the j30 has a nut instead of it just locking in so a pulley remover will not work for this. Has anyone else had this problem?
fourdrinie
Car: 2019 Q50
FSM shows a snap ring inside of the pulley....is that what keeps it on?
suicide commando
Not sure what a snap ring is or where it's located
fourdrinie
Car: 2019 Q50
do you have the FSM?
ST-26 shows the exploded picture of it...
suicide commando
I'm looking at the diagram right now. The snap ring is in the shaft. The nut is what I need to get off. I'm just not sure how I go about getting the nut off
fourdrinie
Car: 2019 Q50
seems like you are going to have to put the pulley in a vise to hold it still, then wrench the nut off while holding the pump body still
suicide commando
I'll try opening it up from the back to see if that's what I have to do
suicide commando
I got it. I had to clamp the whole pump in place and put a Allen wrench into one of the wholes on the pulley and the bolt whole in the pump. Then it came off when I used a socket wrench.
