power steering problems
shon4145
Car: Nissan frontier 2000
Ok, I just went and exchanged the broken pump for another one. I installed it and the same damn thing happened it worked for a few seconds and pop it stopped pumping. This is getting pretty annoying, does anyone have a solution or a suggestion
95hb
Car: 1995 nissan hardbody
first thing i would do is check all the lines and make sure everthing is tight then i would bleed the system by raising the front tires off the ground take off the res ca then turn the wheel lock to lock while its running make sure to keep the fluid top off or else you'll have to do it again its easyer with 2 people
RT22
Car: 1991 nissan hardbody
Sounds like a clogged line
