Power Steering Problems / J30
vocoder
Hey,
It all started last year. Wheel handling became stiff. I let mechanic see what the problem is and he replaced the P/S pump. But that didn't fix anything. I continued to drive it like that. About two weeks ago, after five hours on open sun (100 F), wheel became extremely easy to handle. Everything was like it was before. I hoped it would last forever, but it lasted few days and now everything is the same. Does anybody know what could be the problem, cause I doubt that the P/S pump is failing, cause it's new. Also, I was trying to follow the manual procedure (checking voltages) but I dont know where to begin cause I dont know where Power Steering Control Unit is located. If anyone knows, pictures/schemes would be very good .
Anyway, if somebody had the same problems, please let me know. I think it's not the P/S pump because manual is stating that the P/S system is controlled by speed sensor and if it fails, P/S defaults to "fail-safe" condition common when driving under high speed = stiff wheel during high mph.
Thanks in advance
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I would check the power steering solenoid.....
vocoder
can you tell me where exactly is that solenoid located????
and how can i check it????
thanx
shortlid
Car: 1999 Honda Accord EX 5spd M/T
What type of Power Steering fluid is best for our J's system?
driverdriver
Car: NICO's longtime resident Canuck!!!
I've used the stuff available from Nissan. Up here it costs the same as an aftermarket PS fluid found in any auto store.
shortlid
Is it any diff. from Power steering fluid (light amber color) or is it red like ATF??
joe06mu
Car: infiniti j30
I have a similar prob. there is a leakage on the high pressure hose taking the fluid to the pump. Listen to the noise it makes when you start it. I suggest that you carry around a bottle of power steering fluid and keep feeding it every morning before you drive off. I am looking for used hose because Nissan charges 360 for it!
Defiant
Car: 1997 J30
joe06mu wrote: I am looking for used hose because Nissan charges 360 for it!
Insanity. A hydraulics shop should be able to crimp one up for $30.
shortlid
WOW $360! What type of hydro shop should be bale to fab a hose up? Made out of btter material I bet!!
Defiant
Car: 1997 J30
Check the yellow pages for hydraulics. If you take in your hose, they should be able to remove the current ends, put in a fresh section of hydraulic hose and re-crimp the ends, probably while you watch.
joe06mu
Car: infiniti j30
thanks!
95InfinitiJ30
Car: 95 J30
I signed up with this forum to get help for this same case and as soon as i got on here the answer in which i had a question for was answered. THank you guys..
One more thing, would you guys mind showing a few pics of which hose i should add clamps to??
