Power Steering problem
DeathBy240SX
Heres the deal, I bought an SR and it came with the Hicas pump, I bought a KA24DE pump as with the non-Hicas SR brakcet they will work. Also you need to swap the pulleys.
Here is the HICAS pulley
THE KA24DE pulley
A non-HICAS SR pulley
If the pics dont work go here
The problem is I cant get the SR Hicas pulley off the pump. As you can see there is not just a nut that you can take off and the pulley slides off, like the KA and non-HICAS SR pumps. It is threaded on the inside. So how do I get it off, and if I do get it off, will it fit on my KA24DE pump? I am assuming it wont, as the KA pulley is completely flat so that a nut can be put on, but the HICAS pump sticks outward so no nut could be attached. Is there a USDM pulley that I can use, off a Senta SE-R or G20 or something? Any help would be greatly appreciated.
VitaminT
Car: 93 240sx SE
I am really not sure what to say. Another member here I believe said that the KA pulley would work if you flipped it around. Is the non-HICUS KA pulley 4 rib?
DeathBy240SX
VitaminT wrote:I am really not sure what to say. Another member here I believe said that the KA pulley would work if you flipped it around. Is the non-HICUS KA pulley 4 rib?
Nope it is only 3 and is bigger in diameter.
VitaminT
Car: 93 240sx SE
Are you counting the ribs on the pulley or the belt? I believe from your pic that the SR is a 4 rib belt (3 rib pulley). So if the offset is "okay" then I don't see a problem. As long as the size difference isn't too much that shouldn't matter. And even if it is you could always try it and see how the steering feels.
VitaminT
Car: 93 240sx SE
BTW...do you know if the KA-de bracket will mount to the SR block?
DeathBy240SX
The KA pulley is one rib less than the SR pulley. As far as I know the KA bracket will not work, but I dont have one so I havent tried it.
VitaminT
Car: 93 240sx SE
Did the SR hicus pump have a bolt in the end of the pump shaft?
DeathBy240SX
Nope, I have found out its reverse threaded and wont work with the KA pump.
DeathBy240SX
Anyone know if there are other USDM pulleys that will work???
SpeedRacer1
Car: 1990 240SX, G35
Like I told you on NWN, remove one of the sets of veins to disable one of the high pressure lines. Then cap it off, this is what everyone with a Hicas pump does to use them. You cant switch pulleys because the Hicas pump is connected all the way through the ps pump, its not meant to be removed. Hence the reason you cant get that pulley off.
If the serial number is what I think it is, 49132-52F00, then the only compatible subsitute is off of another S13 SR20DET PS pump.
DeathBy240SX
No worries, I found someone who will trade my the whole non-hicas assembly for my hicas assembly!
gtune4
Car: toonah
well if that doesnt work out, all you have to do it have someone make a bolt/plug for the second outlet on the pump, the one in the rear. also take a part the pump and remove the little metal fins from the rear pump on the inside. it will all make sense when you do it.
thats what i did, i had the same prob
