DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri May 19, 2017 8:40 pm
There is no "setting" to the powqer steering that I am aware of...the system is very basic, a hydraulic system where the fluid movement causes the steering to be easier to move. Leaks and low fluid or plain old worn out (VERY common) rack or even sometimes suspension issues affecting the geometry such as the FUCAS are the main culprits for notchy, slack, or overly sensitive steering with the Z32.
I suspect your FUCAS are FUCA'd...haha. But seriously, jack one front wheel and grasp the edges of the tires at 2 and 7 as on a clock, and try twisting and lifting at the same time, feeling for anything to start making clunking noises up and towards the back of the wheel wells...the FUCAS. Common, and they also show their failure with excessive camber when on the ground and insides of the tires worn more than the rest, but no toe-in problem.
