Eskimo91q45 »
https://forums.nicoclub.com/eskimo91q45-u205434.html
Tue Aug 21, 2012 12:38 pm
Okay so i have this 91 q that has a P/S problem when you turn it the pump seem like it goes in and out and growls. it had a leaking high pressure hose bought a new one solved the leak and still acted up so i replaced the Pump and bled it still acts up so i was wondering if this was a problem in the rack or if maybe the speed sensor for the pump is bad? almost out of ideas to fix it
though of taking tie-rods off wheels and turn the wheel and see if the rack is sticking i don't know how to test the sensor or if there's other components i should look at? any ideas will help at this point. thanks
