I checked the level every week. Level was fine. I'm pretty sure it was the stress of drifting and AutoX that killed it and 190K of driving.hek1620 wrote:mine does the same thing(not work too well) if i try to turn the wheel to quickly sometimes. or if i'm drifting it doesn't let the steering wheel spin freely when the car is in transition. i'm guessing its just time for a new rack. any suggestions? hey 574-240sx, u were probably leakin more than u thought thats probably why ur pump went.
u should make a writeup of thischmercer wrote:sounds like you guys pumps are going out / you are boiling the ps fluid. this started happening to me when i started drifting on bigger tires on the front, got a z32 ps cooler off ebay, plumbed it up, works perfect.
