you explain one more time i still dont get it??driftmyke wrote:unbolt the other end of the line from the rack, then put the line in the vice and use a set of vice grips to remove the hard line from the pressure line, then use the vice grips to install the hard line to the new pressure line, then reinstall into car and bolt back to rack and power steering pump and your good to go
