gtune4 »
https://forums.nicoclub.com/gtune4-u9024.html
Mon Dec 20, 2004 2:05 am
i guess knowbody else can wire this **** up.
i would say use ecuwire to p/s switch and other wire to sensor ground
i have recirc, idle at 750, speed and p/s switch hooked up and still get a little idle drop.
i believe it is in dirty idle control valves that we get half of our probs.i do not know if it is ok to do this, but i took strait carb cleaner, not fuel inj cleaner, and sprayed it directly into the hole where the idler screw is with the motor off and the screw out. i tried my best to fill it up. then put it all back and cranked the motor for a little bit. then gave it a little thr. to get it to start, and blow all the old carbon out. the idler worked well for a while, then the performance went down. i some blowby getting through my turb and think that is why the idler gets dirty. now that i have my gtune catch can, i will reclean and test.
