Try more like 4000, according to the sticker on the door.jr_ss wrote:D21's heavy, you're joking right? A single cab weights less than an s13 coupe. The extended cab weights in just around 3100lbs w/ the 3.0l V6.
yes but the sticker on the door is when the truck has a full load and full cab not empty weightStank wrote:Try more like 4000, according to the sticker on the door.jr_ss wrote:D21's heavy, you're joking right? A single cab weights less than an s13 coupe. The extended cab weights in just around 3100lbs w/ the 3.0l V6.
Thanks for the info on building them custom with -6an fittings, looks like it will work great.
^- this information is correct... The sticker on the door is weight capacity.biker234432 wrote:yes but the sticker on the door is when the truck has a full load and full cab not empty weightStank wrote:Try more like 4000, according to the sticker on the door.
