Power Steering on a 1990 240 w/ SR
Nismo_180sx
Car: 1990 Nissan 240sx SE Redtop SR20DET with bolt-ons
I just need some clarification on somethings before I go at installing everything. I have a 1990 240sx hatchback with a redtop SR20DET. I have (I assume) the KA PS pump, I purchased a new fluid resivor from Nissan for a 91-94 240sx, along with the High pressure and low pressure hoses for a 91-94 240sx. and I also got all new copper gaskets and bolts for the hoses and all. I purchased the car with the swap already done (halfassed) so I'm cleaning it up so to speak. I was wondering if there is anything that I missed before I attempt to install the PS. I have the pump bracket (?) that connects to the block that the pump connects to also. I'm wondering if the KA PS pump will work as long as I have the right hoses and resivor. I used search and found out what all is needed but I never found a clear answer on which pump to use. I even searched vendors websites like heavythrottles SR install guide.
Thanks for any help.
Jeremy
Nismo_180sx
Anyone?
S13240
Looks like you covered it all.
Nismo_180sx
THANK YOU for answering my post. I've been so stressed that I had forgotten something.
Thanks again,
Jeremy
